I know someone who swore by those tires and had several sets with good results. However, depending on the truck and use (4X2 or 4X4?, 100% on road or some off road?, fire roads or rocks?.....) a different load rating might be a good idea. If you are towing a boat, I would suggest stepping up to a higher load rating.
Also, rather than staying with the stock size of 265/70-16, I would step up one size to 265/75-15 which comes stock on the PRO4X. This size actually corrects the speedometer error common on the SV model as it seems the Frontier was calibrated for the larger size across the platform.
I ran E load rated Hankooks in the 75 size on my Frontier with excellent results. Some will say that the ride is 'harsh' or 'rough' with an E but I found the difference to be minimal. The benefits FAR outweighed any discomfort.... better handling, increased sidewall strength, better puncture resistance, increased off road traction and the ability to air down further while off road. The higher load rating will also be a benefit while towing your boat as the tires while 'squirm' less and help with handling at speed.
Does the stronger side walls make the tire stiffer then? I live in MN and I can't afford to get normal everyday tires and a set of snow tires so I can't have to stiff of tires. My boat doesn't weigh more then 1500 lbs soaking wet so I'm no afraid of the truck being able to pull it. Then again this is my 1st truck so I can't know much of what it can and can't handle.
I just bought a set of Cooper AT3s. So far I am very happy with them. I got standard load so they ride as good or maybe a little better than stock. I can't tell that they are any louder than stock. I stepped up a size from 265/70/16 to 265/75/16. It has a little more rolling resistance now and I can feel the increase in ride height. The handling does not seem to be impacted much.
We recently got snow, and I found out how useless my worn out long trails were. Hopefully these will perform much better.
very pleased with my cooper ATW a legal snow rated all terrain tyre, + going to a 245-75-16 with almost identical load + diameter saved me $$ + 4 lbs of unsprung weight at every corner. ride is good + fairly quiet as its winter + windows are up at highway speeds! drop them in town for our fresh air loving dog!!!
Related Threads
Nissan Frontier Forum
1.9M posts
113.5K members
Since 2005
Welcome to our Nissan Frontier Forum! A premier community to share your mods and builds. Chat with like-minded Frontier owners.
