Here's the story, the wife's suv was in a minor accident so I let her borrow my car and I'm driving the loaner. The rental only had a Frontier Pro 4X so I took it. I've had it for a week and I for the most part love the truck. Below are some of the buts...
Little annoyances with the Frontier (Pro 4X)
1. Doesn't shift soon enough from 1st to 2nd. Even with a fairly light foot, the tranny doesn't shift until around 3,000 rpm. That's relatively high specially for a truck. Not to mention that 1st gear is quite low (I understand the need for pulling) but for daily driving I wish it shifted sooner and probably help save a little on gas.
2. Rear tail gate that locks when it wants to. Good God does this annoy me. I want to lock the tailgate to help minimize its theft. From what I read, locking the tailgate is to first turn the key counter clockwise, then turn clockwise. I have only been successful in locking it once. Every other time it fails. I don't want to turn the key any harder in fear of breaking it off while inside the hole. I looked online and on youtube and I see tons of people experiencing this problem.
3. Inaccurate gas gauge. I read that the tank holds 21 gallons. The gauge was coming close to empty. The dte was about 25 miles. I know most manufacturer allows about 2-3 gallons when the empty light comes on. So I decided to fill up. The pump would stop working after I put in around 15 gallons. I turned the key to the on position and it was only displaying 75% full. I decided to pump more gas. A second later it stops pumping again. I looked at the gauge and it was in between 3/4 to 1. It stopped moving so I decided to continue pumping gas. 2 seconds later the pump stops. I little bit of gas splashed out so it was obviously full. I started the engine and after about 2 minutes the gauge climbed up to full. It was actually above full. I'd say dial was about 20% above full.
4. Why no grab handle (by the A pillar) for the driver? Other trucks have grab handles to make it easier to get in and out. But not the Frontier. WTF? The passengers have a grab handle but not the driver. I use the steering wheel to pull myself in the truck.
5. Steering mounted radio buttons. Good God I hate it. I find myself accidentally pressing the track selector when turning the steering wheel in tight spaces. I know it won't kill me but when listening to long audio files (over 30 minutes long) and you accidentally switch tracks... so annoying. The nubs should have been shorter or have smoother edges.
Likes
Very smooth ride. I was actually quite surprised. I've been in other 4X4 pickups (Tacoma) and the Frontier was smoother. I'm guessing the 4X with offroad suspension makes it smoother.
Vehicle height is perfect for a short person like me. 5'6" and I can reach into the bed to pick up stuff. Getting in is actually easy, not as high specially for a 4X4 model.
Insurance rate is actually not bad. A little cheaper than a Tacoma. Probably because Tacomas are more likely to get stolen.
Rockford Fostgate stereo with the small subwoofer is quite good. Can't complain.
Simple. I know many people criticize it for being archaic but it works fine. Toyota "modernized" their Tacoma and most people hate it. Even Taco veterans. They threw in a Camry engine and ripped out a tried and true motor for the sake of being "modern". Being simple is why I like the Frontier.
I was looking at these:
https://www.carmax.com/car/16647220
https://www.carmax.com/car/16654413
https://www.carmax.com/car/16531664
Those prices aren't too bad. Actually at those prices one would only get a stripped Toyota Tacoma with a 4 cylinder engine. Eww. What should one keep a close eye out for when shopping for used Frontiers? What's prone to break or have problems? I know I'll probably crawl under the truck to make sure the previous owner didn't literally drag it down a mountain of rocks.
I know I can probably get an SV or another trim, and save a couple of grand. Is the Pro 4X worth it? 4X4 isn't a must, but I might as well if the difference in mpg is 1. Are they more maintenance? The most offroading I'll probably do is light trails. Probably never tow.
What do you guys think?
Likes
