1 - 11 of 11 Posts
Hello everyone! I currently drive an 01 Ram 1500 extended cab, but recently sold my 21' boat. I'm looking for a smaller crew cab truck now since I don't need such a big truck, and hopefully for better MPG.
I'll still need to be able to haul jet ski's and a rzr 800 with trailer, im thinking a 1st gen frontier would be able to haul it just fine. Got an appointment to look at one this afternoon, but it is a manual and the dealer is asking $8k for it. depending on mileage and accessories we will see.
Anything in particular I should be looking out for in the 1st gen trucks?
IFF 3.3 V6, then timing belt change schedule is every 105k miles.
Vendor
Welcome to the site! Thanks for joining us. You've came to the right place - lots of knowledgeable people here who can help you when you get what you're looking for. Good luck with the hunt and ask away if you need any info.
1st generation are great trucks. Depends on your part of the country, but rust is most important thing to check.
For reference, i'm not sure where your located at but I picked up a 04 XE CC long bed with 180k for $3k at a dealer just last week in NJ. It needed a complete tuneup including timing belt and all the fluids changed. It needed a new muffler new rear bumper, and shocks all around. It also has some surface rust on the frame, but the bed is solid. I think i'm about $800 in for maintenance and cosmetics including eastwood rust encapsulator which I plan on using for the frame.
As for recommendations I would check under the bed if it has a liner. Most of the high mileage trucks I found in my area had the beds rotted completely out and the owners not even knowing because the liner was hiding the damage. I also found the timing belt to be much easier to do than doing the valve cover gaskets. Taking that intake manifold off really sucks.
Thank you for your input. I did read up about your adventure as well :) . I am in East TN so rust shouldn't be a huge issue, but I will check everything. We don't have a lot of rust issues down south like you guys do up north. I have a mechanic that should be able to work on it, doing the belt and other maintenance. Have you hauled anything with it yet? I would be hauling a RZR 800 on an 8x6 trailer. Probably not more than 2500 pounds so im thinking the frontier will be fine.
I have not tried yet, Today was the first day I got it back on the road after driving it home. I wanted to get all the maintenance done before I drove it because the timing belt was a big wildcard. In terms of hauling I'm sure it will do just fine on flat land. I'm coming from a 04 Titan so its quite a bit of difference, but I really only need my truck for the occasional homedepot/dump run, and a few jobsite visits in the city here and there so the lack of power should be fine for me. I do plan on installing a hitch one day as I occasionally dream about some project car deals that I would like to be able to tow home one day, but its a good chance my wife will never let that happen lol.
Gottcha, same here, coming from a Ram 1500, but I hate the 10mpg. Hoping the frontier would be better. I only tow it maybe twice a year, and there are pretty big hills around here, just have to not use OD and take my time. The truck im looking at already has the trailer hitch which is a plus.
1 - 11 of 11 Posts
