Starting work on the jerry can holder. Until I get the existing parts back from powder-coat I can't finish, but I can at least start.
I'd started out looking at off-the-shelf components that might make the build easier. Unfortunately prebuilt three-can holders are very expensive, like the better part of four figures. Then I started looking at telecom parts, and I stumbled across wall-mount shelves for non-rackmount electronics. The original model from vendor Startech was unfortunately discontinued, and many others ship as four-piece kits I found this:
This is a Middle Atlantic wall shelf, meant for use in equipment rooms for gear that is not rackmounted. I ordered this one in particular because of the several manufacturers of similar shelves, Middle Atlantic and the discontinued Startech models are the only ones that are shipped already finished, welded together in one piece. Others are shipped as knockdown kits and held together with screws.
Inside it's a little over 20" wide, and in the orientation it was designed to be installed, around 14" tall along the wall, and jutting-out around 17" from the wall. In the orientation I have it shown it's sitting on what would be its back, with the vented panel being 17" tall with a lip at the top, and the bottom panel being 14".
For reference, a NATO-standard jerry can is 18 1/4" tall x 13 1/2" deep x 6 1/2" wide. Three such cans are 19 1/2" wide. There are several manufacturers of water jugs that are similar dimensions.
Here's three jerry cans on the shelf:
The lip overhangs the openings on the cans, just a little, potentially just enough that depending on how I ultimately settle on retaining the cans they won't be able to be opened while secured:
For reference, this shelf unit was $180. Not cheap, but being built in one piece and welded, and rated for 200lb static capacity by itself, just mounted to studs.
...to be continued...
