Mostly finished the tire-side swing arm today. Remining to do, weld on caps over the open-ends of the tubes, confirm all welds are complete and not just tacks, run a fillerless TIG pass over the welds to clean them up, grind off the millscale, drill the hole for the future jerry can swing arm pivot, weld the nut on for the jerry can swing arm pivot, clearance the body of the truck at the rear bed for the driver's side swingout, and then have these parts powdercoated.
The arm clears the tailgate. This was before I attached the latch hardware.
It looks like its too far to the right but the photo was taken when I was much closer to the truck than any vehicle rightly would be.
The tire mounted and tightened down just clears the side of the bed, the tire rubber barely brushes the light on the raised white letters as it is rotated.
Tailgate face clears the arm when opened by around an inch and change.
Tire is above the original departure angle.
Just under an inch clearance from the tailgate to the arm, and around 3/4 inch between the tire and the arm.
Tire protrudes rearward around 5" more than the tailgate does when lowered. This was one of the goals, to avoid the swung tire sticking out like crazy.
And the tabs that the swing arms will latch into.
Just after this I screwed up. I installed a plate on the swing arm to align with the tab, but I didn't realize the arm wasn't swung-in all of the way. I attached and surround-welded the plate on in the wrong spot. I spent over an hour fixing this, I knocked out the tab (just tacked) to cut it shorter, then broke my tap when I was tapping the threads for the hook, then had to make another tab altogether, cleaning up the old steel and welding it in once I'd gotten the alignment right.
...to be continued...
