It seals fine enough to function, sure but it could use improvement. I have an Xterra and Frontier and they both accumulate a lot more dust and debris in the box than any other car I’ve dealt with. The sides of the box where the clamp together is also not very precise, there is a bit of play or doesn’t align perfectly. A closed air box would improve that. It appears you misunderstood, I did not say I wanted a CAI.
And my point is that there is accumulation after the filter.
Honestly, it sounds like something is wrong here. We all have the same vehicle, but you are experiencing accumulation of dirt after the OEM filter location, and I am not at all in the least. I run WIX filters. Maybe give that a try. Something is definitely wrong here. For further assistance create a thread dedicated to it since this one is about the Z1 CAI you are uninterested in purchasing. Reading your problem earlier it was so random it sounded like you had the Z1 intake and had dirt after the filter media, which would be horrible, and it is, but...to be clear, you have a problem with your oem intake and not the Z1 to everyone reading in. Hope it gets resolved. It's definitely not normal.
There is zero play with my oem intake box latches, for the record. It's pretty tight, definitely air tight as it should be.
Perhaps you can lift one off one of the oem boxes off the gentlemen, or ladies, who have made the switch to the Z1 CAI
