Has anyone with the PRG coil overs experienced metal shavings come from the top of the coil over when lifting the front end? will post pics in a few. any help is of great use.
PRG sells coilovers so witch brand?
radflos 2.0. sorry for not clarifying earlier. here is a pic.
did you adjust them with the weight of the truck on them?.
That is from the spring plate turning against the rod end. Those things are under tremendous pressure when you dial them all the way up static. Then you add double the weight of one corner of the truck do to leverage, and start turning things. One little burr can gall the aluminum.
I wouldn't worry about it, but if you ever break down your shocks might want to clean the rod end up. In the future jack the truck up to make height adjustments, if you didn't this time.
yeah i had both wheels off with jacks supporting the truck to assure no weight was on the coils. i havent noticed any difference in performance or ride since i adjusted them yesterday, so i will just keep going till something happens. thanks for the input.
Remember that the C/O's height are limited internally.. Crank'n em' past that point won't get you more lift, just load the spring up more.
