1 - 4 of 4 Posts
P0430 Catalyst sys efficiency threshold bank 2
What does this mean? And how come when I lose my job my truck breaks?
What does that mean?Basically this means that the oxygen sensor downstream of the catalytic converter on bank 2 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
SymptomsYou will likely not notice any drivability problems, although there may be symptoms such as a rough/hard idle when cold.
CausesA code P0430 may mean that one or more of the following has happened:
The catalytic converter is no longer functioning properly
An oxygen sensor is not reading (functioning) properly
There is an exhaust leak
Possible SolutionsFirst, inspect for exhaust leaks.
Next step is to measure the voltage at the oxygen sensor on Bank 2. In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
One thing to note is that many vehicle manufacturers offer a longer warranty on emissions-related parts. So if you have a newer car but it's out of it's bumper-to-bumper warranty, there still may be warranty on this type of problem. Many manufacturers give a five year, unlimited mileage warranty on these items. It's worth checking into.
Johns nailed it pretty well. If it is the cats, they are covered under 8yr/80000 mile warranty
Mine has that code. Scan says most likely problem is
1- Large Vacuum leak
2- Fuel stystem fault
3- Ignition system fault
4- Failing cat bank 2
1 - 4 of 4 Posts
