1 - 4 of 4 Posts
Has anyone been able to find a good looking 2nd Gen headlight assembly that does not have chrome?
Reactions: 2whlfront
I've stumbled across a couple on eBay. They're obviously gonna be questionable quality. I have no issue buying Chinese for some things. Critical safety equipment like headlights? I'll stick with the known quality Chinese manufacturing.
If you're comfortable with doing the work yourself then I'd recommend either doing a hid retrofit as suggested above or just painting your chrome housings. Either way would require baking the housing to get it apart. There are several threads here that'll walk you through it. All the aftermarket headlights I've come across on other vehicles made the light output worse than the factory ones. Here's a pic of when I did my headlights. The link below is the post that I referenced when I retrofitted my headlights.
http://www.clubfrontier.org/forums/f23/x_mods-projectors-76001/
1 - 4 of 4 Posts
