Yeah all you need is a regular timing lightI can check/set the timing on a 2002 VG33 using a standard inductive timing light, correct? Don't need any weird tool right?
Yes and make sure the arrow on the pickup clamp is facing the plug if yours has an arrowDo you use the number 1 spark plug wire for the inductive pickoff for the timing light?
