1 - 14 of 14 Posts
Using 1/2 EMT and a bender I made this for about $10. After bending the thin wall it was covered with poly pipe insulation. Baby power helps to slip it on. Two hole straps were used with a coupler at the base for a footing with a set screw. The idea was to have something that would slip off when not in use.
Very clean set up. Nice work
Nice clean look!! I've seen that tool with the blue handle hanging in my father's garage for years. I learned something new today...
pretty good bit of ingenuity there, good job
great idea nice job :fantastic:
Pretty clever.... you an electrician?
Thanks for the comments. I wrapped the poly insulation with black duct tape to prevent the braze-ons from tearing it.
1 - 14 of 14 Posts
