Hey all,
Got a "new to me" '13 Nissan Frontier Pro4X "Metallic Blue" with 9600 miles on her..
Performance Mods:
UpRev Osiris - Cajun tuned by Joe @ CajunBpipes. Highly recommended!
aFe Momentum GT Pro 5R Stage-2 Intake (formerly an Injen PowerFlow Intake)
XTP IMS
Doug Thorley Long Tube Headers
Stillen LightWeight Under Drive Pulley
aFe MACH Force-Xp 2-1/2" to 3" Cat-Back Stainless Steel Exhaust System w/High Tuck Tip
aFe Silver Bullet TBS (I got it cheap!)
Doug Thorley B-pipes with Magnaflow High Flow cats
R1 Concepts Slotted Premium Rotors with Hawk LTS pads.
Stainless Steel Extended Brake lines
4.10 Gears (front and rear)
Suspension Mods:
Titan Swap w/M205
Dirt King UCA
OEM Titan LCA
Extended Heim Outer Tie Rods
Radflo 2.5 Extended Travel with 650# springs
Radflo 2.0 Rear Emulsion
Alcan 3" Leaf Pack w/ Military Wrap and +500lbs
UBolt Flip kit w/ custom mounted 4.5" bump stops
Ballistic Fab Boxed lower shock mounts
Nisstec Adjustable Shackles
Armor:
P&P Engineering Level3 rock sliders
Hefty Fabworks full steel skids
Hefty Fabworks Aluminum front bumper (ordered!)
Exterior Mods:
OEM Hood Deflector
WeatherTech Dark Window Deflectors
OEM "Midnight Edition" Frontier Grille
13" AntennaX Offroad Radio Antenna
Sylvannia ZXE 9007 HL, and Nokya Hyper Yellow H9 fogs
Level8 Tracker Pro 16x8.5 Wheels
315/75/16 Goodyear MTR/K
FormulaOne Pinnacle ceramic tint 35% front, 7-8% tint on rears
Poison Spyder Hood Louver
Interior Mods:
WeatherTech mats w/ custom Pro4X logos (Thanks @NissTier - http://www.clubfrontier.org/forums/f9/custom-weathertech-badges-177194/) (http://www.clubfrontier.org/forums/f103/chaosminionx-s-build-13-pro4x-180937/#post2315826)
Cobra 29 Nightwatch CB w/ 4' FireStick
OEM 2015 Xterra Navigation Unit (everything works)
Driver and Passenger Paracord Grab Handles
Miscellaneous Mods:
Saikou Michi Oil Catch Can
Derale Atomic Cool 15 Row Auxiliary Transmission Cooler
DIY Grounding Kit with 4AWG wire.
Fluids
AMSOil Signature ATF - Transmission, Transfercase and Powersteering
AMSOil Signature 5w30 w/ AMSOil EA Filter
AMSOil Severe Gear 75w90 (M205) 75w140 (M226)
AMSOil NLGI#2 Grease
Pentosin SuperDOT4 LV Brake Fluid
Here she is when I get her!
I will add some pictures of what I got done so far as I get them.
2/23/15 - Got the exhaust done at Lou's Custom Exhaust in Waltham, MA - Originally I was just going to swap the Y for a magnaflow, and install the Super44.. The guy who did my work pulled me out into the shop and ran an idea by me.. We ended up cutting another inlet into the muffler so that it was Dual-Inlet into single out, this cut the Y-Pipe completely out of the equation, they did a great job and the truck sounds mean! I will get some sound clips as soon as I get it back from having tires put on it.
EXHAUST CLIP!
2/25/2015 - Swapped the stock 265/75/16 BFG Rugged Fails for 265/75/16 BFG All-Terrain T/A KO, about 30k miles left on these tires, they were on my old truck, going to switch to 285/75/16 BFG All-Terrain T/A KO2 when these wear out.
Dirty shot of it, gotta wait for this winter to end before I will be able to give it a good waxing and cleaning..
2/28/2015 - Added new bulbs, went with Sylvannia Silverstar ZXE 9007 for the headlights, and swapped fogs for modified H9 Nokya Hyper Yellows (H9 is 65W vs 55W on H11 which is the default bulb)
Also! Cleaned up shot of her after I got it registered in PA, my wife decided to photobomb the picture.
3/5/2015 - UpRev Osiris! Just waiting on my E-tune now
3/17/2015 - Stillen lightweight under drive pulley installed, and Injen intake cleaned up!
Performance Mods:
XTP IMS
Suspension Mods:
Titan Swap w/M205
Dirt King UCA
OEM Titan LCA
Armor:
Exterior Mods:
OEM Hood Deflector
Interior Mods:
Miscellaneous Mods:
Fluids
EXHAUST CLIP!
