Wheel spacers are dangerous. Only you can make it save by always checking the fastener for proper torque. Its fatiguing if you ask me. Buy rims with proper of set to fit your liking.
Oh well. Most people are in the comfort zone so luck is on them side. Wheel spacer also change the alignment of the vehicle. So if he get into a accident on public road the insura can claim the owner change the wheel alignment spec and this is outside factory safety standard to cause the accident even if the wheel spacer owner is not at fault. The vehicle must maintain DOT and EPA minimum safety standards. Only use DOT of EAP standard equipment. The insurance knows you are a third party and don't deserve anything.
I'm guessing some of the posts must have been removed here cause only 4 are showing up.
Regardless, I have the same exact spacers installed for nearly two years and they are fine, not a single issue ever, lugs stay tight, no issues at all with vibration, quality product, quality manufactured. If anyone's hating, it's probably due to cheap Chinese FleaBay and BeezieBoyz specials that aren't drilled concentrically and use inferior materials. Wheels and brakes are not places to cut corners and go cheap. Be safe out there.
I had spacer/adapters on my 06 so I could use Toyota wheels, for 6 yrs, 150k miles, never an issue. Oh and by the way I was involved in an accident. I was t boned and ins never said a thing, in fact ins never even looked at my truck. Yes it was repaired without issue.
