Hi guys so my clutch recently started slipping under load mainly on freeway, i have about 123k on her (2012 pro4x).. soo i obviously want something a little stronger clutch wise, so i decided to go with the centerforce II that being said the disc diameter is 10.4"/ 264mm. Now i wanted to also go with a new flywheel as well since im in there and the luk one from summit states that the flywheel for that truck which ive seen alot of people matching on here has a disc surface diameter of 9.813" now my question is will that work? Or do i need a bigger mating surface flywheel?! As much as ive searched i havnt seen any topic covering the diameters and such.. and good advice is appreciated! Mods [Leveling kit/33's]
Thanks, Lou
Thanks, Lou
