1 - 14 of 14 Posts
I have my Samsung Galaxy S7 synced up to my 2016 Pro4X and I can't figure out how to listen to music from my phone. I know I can use an auxiliary cable, but I figured I would be able to just listen via Bluetooth.
Can anyone help me out with this?
Thanks.
Thanks.
Use the media button to select Bluetooth. Open the app on your phone you want to stream. It will play through the speakers.
· Admin
^ same here with the non nav unit on a '13.
Non-Nav 2015 Desert Runner here and it plays music through bluetooth just fine for me... Rolling Samsung Galaxy Note 7 to Non Nav stock unit.
Audio main operation
To switch to the Bluetooth® audio mode, press the MEDIA button repeatedly until the Bluetooth® audio mode is displayed on the screen. The controls for the Bluetooth® audio are displayed on the screen. Use the Preset 3 button for play and the Preset 4 button for pause.
That is all...
Hope this works for you.
· Admin
This is the non nav unit in the '13s, no MEDIA button. Hopefully they changed it in the later models @Kagia and you'll be able to follow @racquetballer instructions.
Same, you gotta plug it in and last I checked it seems to only work with iphones... No android, sorry...
Bluetooth works fine on my Samsung Galaxy Note 7 without wires in my truck... No need to plug in here... I'll post up a picture when I get a chance.
Here's a picture of my head unit and the Samsung Galaxy Note 7 paired bluetooth wirelessly. OP has a 2016 so it's a year newer than my rig so I would hope it would work for the OP too. BTW my older Samsung Galaxy Note 4 worked as well.. YMMV
Same in my 2015 Non-Nav.
Push Settings > Bluetooth to pair your phone.
Push the MEDIA button until it says "BluetoothAudio"
When the phone is connected, you will have some icons show in the top corner next to the clock.
Open your favorite music app and hit play.
Make sure your phone's volume is up.
1 - 14 of 14 Posts
