please someone im in middle of install titan swap and i cant take off the old brake lines
thanks for sharing? idk what your wanting here?please someone im in middle of install titan swap and i cant take off the old brake lines
this is what i used just go checkersIf you mean to say that you can't loosen the nuts using a normal wrench, you might want to try (what I think is called) a flare nut wrench. It's kind of like a box end wrench with one side cut out so you can slip it over the brake line then onto the nut. It grabs a lot better than an open end wrench. hope that helps.
haha weekend warrior tools, but yes that is the wrench you will need either a 12mm, 13mm or 14mm i cant remember exactly which one but i am pretty sure it is one of those.this is what i used just go checkers
yes i love my Snap-On toolsI had no problems taking mine off, just used my snap on flares as well, love them.
Im slightly jealousAs do I, about 95% of my tools are Snap-On
seriously dude. im still trying to find an angle out on that.Im down. To bad you werent able to have it up here for your first year.
