I wanted to share the solution to a problem I had this morning where I couldn't shift into drive.
I knew it wasn't the shift lock because I could hear it disengage when pressing the brake, and I was able to shift as far as neutral.
I knew it wasn't the transmission because reverse worked fine.
But whatever is hidden by a cover in a car is black magic to me until it gets explained. So I still suspected some sort of locking mechanism or something complicated.
I did a quick search but only found posts about issues with the shift lock. But I found a youtube video that explained clearly what was happening. I'm posting it here because there are too many questions and not enough answers on the internet.
The solution for me was the metal bracket, that puts pressure on some ridges to help keep the shifter locked in position, came loose causing it to butt up against the plastic physically preventing the shifter from travelling further. Re-aligning the bracket and tightening the screw allowed the shifter to move.
