Can't remove crank pulley
13K views 9 replies 4 participants last post by  Uellee
I'm a little confused here.... how far along with this job were you when you went to remove the crank pulley? Unless I'm mistaken you can't use the tool to lock the flywheel until you get the front cover off which requires removing the crank pulley.
