This is my first and will probably be my last attempt to change the dreaded #6 plug on the 3.3L V6.
First off I did my research, read the sticky on the #6 plug removal and removed the hood, used u-joints, extensions... you know the story. The ceramic on the old plug broke off while I was removing it so I carefully used my handy bore scope camera and a brush to clean the debris before I put the new plug in.
This is where the frustration begins! for the life of me I cannot get the [email protected]$n thing to thread properly! I tried for close to 5 hours last night with no luck. It feels like it wants to thread in but gets jammed up after maybe only one turn. I am super scared of cross threading this thing so tonight I am going to borrow the neighbors air compressor and blow out any reaming debris for the threads and hopefully that helps.
If that does not work the only other thing I can think of is removing the upper manifold to hopefully gain more access. Is removing the upper manifold enough or would I have to remove the lower too.
Thoughts? this has me super frustrated!
