https://www.youtube.com/watch?v=LsZ-ZiCHg8g
I've had this problem since I've had the truck. Basically you can be driving then all of a sudden the speedometer and 4wd stops working and the brake and 4wd lights come on. Randomly one time i hit the horn while this happened and they went off. Now every time it does that i just blow the horn, but its getting to be annoying. I've searched and searched to find out if someone has the same problem but I have not seen anyone with the horn solution. BTW it seems to only do this above 60 degree weather, this winter it hardly ever had issues but now since its getting hotter it does it daily. It also seems to do it more at highway speeds and will knock you out of CC. Thanks in advance for any insight.
