NO DTC IS DETECTED FURTHER TESTING MAY BE REQUIRED.
MONITOR NO DTC
ENGINE SPEED: 625RPM
A/F ALPHA-B1 141%
A/F ALPHA-B2 136%
the dealership told me im running lean and its because of a volant CAI and my truck vibrates at idle.
Idle speed is dead on perfect as per spec. It is dumping A LOT of fuel though, so it's reading a ton of air from somewhere. When I had my volant, I watched the fuel trims for a few days, and they were no where near that high. Some members that have been using the powercore filter have been having issues with too much air. If you're running that, try getting an Amsoil or AEM dryy filter, both seem to have remedied their issues. I wouldnt think that you have an air leak anywhere, because the idle would definitely be higher than that. You can get a can of brake cleaner and go around all parts of the intake and listen for it to bog down( truck running). There are a few inherent issues with the volant intakes on some of them. The tube can have pin holes down the side seams, the MAF sensor mount often doesnt seal nicely or can alos leak around the brass bungs.
I also just checked my fuel trims the other day with my Nismo intake on and at idle they were at B1: 101 and B2: 102. Which is basically flat and perfect. If you have the ability to look at long term and short term trims, post the numbers up. Long term trim should be around +/- 5% and short terms around +/- 10%.
It's not a good thing to have it like that forever. Could be other things, as well. Post up your mod list and I'll let you know if anything sticksout.
I just have a Volant Intake i have had it since i have 1200 miles on the truck, im now at 34000. I cleaned and oiled the cone every 9000. its been cleaned 3 times, could it just be shot and need a new one? I also have a custom 2.25 duel in duel out flowmaster muffler. Those are the only engine mods i have. But the dealership just replaced my Secondary timing chains and both tensioner shoes and thats when its stated to shake at idle and run lean, i took it back and they told me its because i have a intake on it. so today im installing the stock air box and going to see what happens. Thanks for your help
