1 - 20 of 21 Posts
I have a question, If i have the AC lift kit/leveling kit and the 2" AC body lift can i fit 35s? or is it iffy?
LowCOG rigs rule. if you have a saw you can fit 35s on a 3in lift with stock fenders, also body lifts are point less on a frontier as you cant do a tummy tuck, ie motor trans and diff lift to have higher ground clearance
I have 6 inches of lift and still had to trim to fit 34" tires. So no matter what you do plan on "adjusting body parts".
Also as mustard already said, at 35" you'll wish you regeared and there are not many options in that department.
nismos have 3.36 so in theory 3.69oem gears should be perfect for 35s atleast thats what i plan on doin this summer
(new tire size/old tire size)x old ratio= new ratio
so
(35/32)x3.36=3.675
or am i missin something here???
ok i wasnt sure
3:69 w/ 35's == no fun.
With 35's a 4:10 ratio will bring you close to stock; but 4:56's are ideal if you use the truck in the dirt. As for fitting 35's with 2-3" of lift; no problem at all if you don't plan on turning. 35's with minimal lift and anymore travel then stock will require some cutting to the pinch weld on the cab as well as trimming the front bumper...at that point if you haven't pushed your wheels out then your frame will probably interfere at lock.
with an auto you will be fine with 3.69's and 35's
with a manual youll want 4.10's
i think im the only auto right now running 3.69's and could easily push 35's with the truck , but right now we are running 33's which is pretty fun haha
1 - 20 of 21 Posts
