1 - 8 of 8 Posts
I have a 2009 Nissan Frontier SE with the 4.0 When I press the brake the temp gauge drops to zero and the idle increases to about 2000 rpms. Also when i Turn on the right blinker or the hazards the rpms rise and fall,with the right blinker on during turns it rocks the truck back and forth like it is in too high of gear and if i am parked it will go so low it will die. with the blinker on the temp gauge goes up and down. The left blinker is fine and nothing happens when it is on.
Also the check engine light is on and the codes are
p0118 cooland temp signal high.
p0113 Intake air temp high
p0451 evap press sensor out of range
p0183 fuel temp sensor signal high
If any one can help me out with any of these problems please do thanks.
its an 09, if its under the 36000 mile marker take it to the dealer to get it looked at.
the frontier is the same thing as the navara. there is no reason they shouldnt work on it. if they wont call other dealers in other countries and see if they will check it out.
1 - 8 of 8 Posts
