1 - 20 of 23 Posts
First of all, I’ve read and re-read all the guides, the manual and already had a few goes at solving my issue.
I fitted my winter wheels this weekend; a set of OEM 5-spikes with OEM sensors still fitted, with new Cooper Evolution Winter tires.
I followed Raine’s guide; turn ignition to ON position, waited until the light went from flashing to solid, grounded wire 6 times, BUT I now realize the light was flashing fast, not slow.
Wentout on the highway for 20mins or so and the light just flashed constantly. So I returned home to try again.
Now, when I turn the ignition to ON, the light comes on solid, it never flashes. I tried waiting the 1 min and grounding the wire and on the 5th touch, the light goes to flashing fast and never stops.
So, I’m stuck. What is the current state of my TPMS system? And how do I get back to relearn mode? ?
Discussion Starter #2
No progress. I drove the truck a few times yesterday. When I turn the truck on, the light comes on solid (never flashes) and stays on solid the whole time I drive the truck.
If you're having trouble getting it into the relearn mode, try grounding the connector, turn the car on, then turn the car off while still grounding it.
Did they check the sensors for you.. could just be bad, just one of them would do it.
Discussion Starter #5
Thanks guys.
I did see this recommended elsewhere and tried it, but doesn’t seem to have had an effect ?
Agreed, could be, but the standard warning for this is the light flashing for 1 min then going to constant, which is where you would hop into relearn mode. Having driven the truck with the light flashing ‘fast’ for over 20mins, I’m not sure if the system is now in some other mode where it is leaving the light on solid. This would be the warning light state for a tire below pressure, per the manual, but I don’t believe the sensors have been registered. As above, if I ground the wire just 5 times, the light goes from solid to flashing ‘fast’ and continues flashing indefinitely until the ignition is turned off.
Questions:
  • Did you have different wheels on with TPMS before putting on the winter set?
  • What year is your truck?
I think he said it’s a 19 with the factory wheels & TPMS, he then bought a set of used SV wheels with sensors but never really checked them and had new tires put on, that’s where he’s having the trouble.
Where?
Anyhow, it could be as simple as the used set of wheels have dead/broken TPMS sensors.
Discussion Starter #9
Questions:
Hey, it’s a 2019 S, so had 15” steelies with TPMS.
Fitted a set of 5-spoke 16” (SV?) alloys with factory TPMS sensors of unknown age.
Advice of tire shop was to try to register the sensors before purchasing new ones. They won’t charge me much to swap them out if necessary. My issue at the moment is that I can’t get back into learn mode to test the sensors now.
Yeah really - I don't see where "he said it’s a 19 with the factory wheels & TPMS, he then bought a set of used SV wheels with sensors..." anywhere before I asked, unless the OP edited their first post and you read it before the edit, or somewhere else.
Well I read it somewhere and I was right.. I think?? Lol I was messin with you anyways! Don’t make me call the post police..
It sounds like you are trying to relearn them using the "different tire pressures" method and driving. It will never complete if there is one or more sensor that has a dead battery...and that would trigger a code, causing the TPMS light to go solid. If you did the TPMS code readout, you'll likely see strored codes.I would recommend getting a TPMS trigger tool, which you can find under $20. Having the trigger tool still won't allow you to register all of the sensors if one or more has a dead battery, but it will cause the exterior lights to flash when registered in ID register mode IF the sensor is good. This will help you determine which sensor(s) are good.
Discussion Starter #14
^^^ Fantastic info mate. Very much appreciated. I’ll look into this for sure and report back
This trigger tool works with our system:
311432
Discussion Starter #16
...when registered in ID register mode IF the sensor is good. This will help you determine which sensor(s) are good.
Any comment on how I might get back to being able to access ID register mode? Right now when turn the key to KOEO, the TPMS light just comes on solid. I doesn’t flash for one minute first, like it’s supposed to.
While we’re on this subject, no need for me to start a new post. Smj.. after you answer Matt’s question I have one.
I put my 16” wheels from my truck on my wife’s pathfinder which has had the TPMS light on for a while.. blinks when started for a minute or two then goes solid. I know the sensors are good because they were working properly on truck. I have not checked to see if air is good on all four “should have checked” I know but I assumed it was and thought I just needed to drive it a bit. That didn’t help, do I need to have them set it? Or me try to do it?
The TPMS sensors are registered to your truck's TPMS control unit. You need to do the ID registration in order to register your truck's TPMS sensors (now installed on your wife's vehicle) to the TPMS control unit in your wife's Pathfinder.
It would be like if you wanted to use a remote key fob from your truck on your wife's Pathfinder; the part would be the same, but the remote would still have to be programmed to her Pathfinder.
Lost me.. so do I need to take it in or do you think maybe discount tire could do this?
If the "grounding the TPMS terminal 6x within 10 seconds after turning the key on" procedure doesn't work, try going through the code flash procedure where you ground the wire constant and turn the key on....then, turn the key off and try to initiate the ID register mode procedure, again. If that doesn't work, try disconnecting the battery for 10 minutes. Once the battery cable is reconnected, attempt to access ID registration mode. If it still doesn't work, check the fuses and last, but not least, go through the TPMS diagnostics in the FSM.
1 - 20 of 23 Posts
