1 - 4 of 4 Posts
I got a check engine light along with the "VDC off" and "slip" lights this week. Well I pulled code p0340 cam position sensor and changed the sensor on the drivers side but the problem persists with the exact same fault code p0340. no other codes present. really scratching my head on this one. Anyone have any thoughts or ideas?
Found this as other possible causes, since you stated your replaced the sensor.
P0340 NISSAN Camshaft Position Sensor Circuit Bank 1
Possible causes
- Faulty Camshaft Position Sensor
- Camshaft Position Sensor harness is open or shorted
- Camshaft Position Sensor circuit poor electrical connection
- Faulty starter motor
- Starting system circuit
- Dead (Weak) battery
Yr, engine and miles = useful info. :nerd:
1 - 4 of 4 Posts
