1 - 12 of 12 Posts
will any one ever make a c200 gear set ?? i want 4:10s so so bad. but i just dont have the money to get a new axle. is there some one we might be able to go to and see if they will do it. there have to be a good amount of people on here who would buy gears for a c200. also just a ? for our front diffs if i want to change the rear i have to get a titan front and get new gears for that correct ?
You could swap in an M226 from a Nismo which has 4.10 gears available..
Once you get the Nismo axle, go here for gears: http://ruggedrocksoffroad.com/super...l-gears-2005-2007-nissan-frontier-p-5593.html
i just dont want to do a axle swap bc it has to cost way more then just gears. ?? has any one who has done a swap give me a price
i found 2 titan fronts but i have no clue whats inside of them or what i need from it
nope!! i tried already no luck just go with the m226 axle
where is the love for the c200 :( so i have to get a m226 and 4:10 gears then what do i need to keep the 4x4
It doesn't matter what rear end you have.
The front 4.10 gears are still not out and they are only coming for the M205 front diff. (titan diff.)
Yeh I new that. I wanted to know if there where diff models of the 205 so I don't buy the wrong one
IF your plans is to install 4.10 gears the it does make a difference witch model you get the M205 from.
The XE frontier has 4.10 gears stock and they have the C200k rear.
U mean the titan ? Right sorry. I just don't no what to look for. Ok all I want is 4:10s.what will I need for that. Like would I just be able to take a titan axle ?? Instead of a frontier one ?
For you to get 4.10's
1) wait for the gears to come out for the the M205.
2) find a M205 diff. All 4x4 Nissan's with a V8 has the M205 diff. Since you are replace the gears just find the cheapest one.
3) get 4.10's out an XE and install them in your diff.
4) front axles from a V8 pathfinder if you want to keep the same trace width.
so i am pretty sure i have a m205 set up. now i just have to find a m226
Discussion Starter · #12 ·
so i just read that the m205 will not have the new gears ready for 6 months thats a little long for me to wait. so what i want to do now is get a m226 with a 3.5 or 3.6 then get a m205 to match. does any one have a chart for what truck has what m205 to have something that will match or work ?
1 - 12 of 12 Posts
