I added the bed tie down cleats that come in the beds without in util-track.Just pop out the plastic plugs and run a tap thru the holes to get the sprayed on bedliner out of the holes then bolt them on.A tie down comes with the bolts and was $5.00 & some change each.The front 2 has to be mounted upside down due to hitting the rail.
