OK...I need to start planning and gathering parts for my Titan Rear End swap. Don't plan on going any higher than 33" tires and currently have the C200 rear end and want to go to the Titan M226. Truck is to remain 2WD so no worries about matching anything gear ratio wise in the front.
To begin with I'm not sure if I should grab a axle housing from a wrecked Titan and stuff some Superior Gears and an ARB in it or if I should just order the bare axle housing from Nissan direct and build it out from there.
Reccomendations on building the strongest setup possible?
Am I correct in saying there are no upgraded axles available yet and just the R&P from Superior? Has going to the ARB and Superior R&P eliminated the rear end failures?
