So, myself and Bigdog went out to URE. I brought along a buddy with a 2008 Z71 that did surprisingly well. There were some guys from thenewx out there and two guys named John that Bigdog knows. We didn't all wheel together though. So anyways, I know what you are all thinking.....used too much skinny pedal and drove like a jackass....not the case. It was a good trip but on the first trail, the first time I engaged my 4wd (not even on an obstacle) I started hearing a grinding/screeching/cracking noise from up front. After turning off 4wd the sounds went away, 4H and 4Lo both had the lovely noise which got my hopes up that I had destroyed my R180 (justifies my titan diff swap!!!!!)
I don't think this is the case. I don't have any flashing lights on the dash and it doesn't make the sounds if I'm in 4wd coasting down a hill, only when I push the gas it starts to make the noise. There's no fluids leaking, no boots torn...no visible sign of damage. Probably two other times, I switched into 4wd just to give the problem one last "F-you" on the trail so I can hurry up and replace the weak link in the truck. We only did the one trail, which I'm glad I at least had that locker or I would have been screwed.
So I now have a question that Bigdog and I were trying to figure out. If I did a M205 swap and a Titan suspension swap, could I use Titan axles or would I need to contact Greg for his extended axle shafts? I have this question because the V8 Pathfinder axle shafts are so bloody expensive new and there's not an absurd amount of those Pathfinders in scrap yards, so I may save a coin by doing a full Titan swap.
What are your thoughts?
Oh and since :worthless_thread: here's where the pics are http://www.clubfrontier.org/forums/f33/whos-up-day-ure-57800/
By the way, Bigdog put his truck into a two wheel stance yesterday in a 4 foot deep mud pit. It teetered on the driverside tires for a bit until it came back down to a three wheel stance which then allowed him to crawl out of the pit. He was centimeters from taking a drink from the brown lagoon!
