Gonna change brake pads on my 2011 Frontier SV 4X4. Anything unusual I should expect,like special tools,or is it just straightforward.Thanks in advance for any help.
I would check and possibly replace the rubber parts of the guide pins also, mine were toast at 60k. Here's the kit and I'm only referring to the rubber that goes on the pin, the outer bushings that come with the kit I didn't need at the time.
Caliper Guide Pin Boot Kit
P.S. use only brake grease as typical parts grease will destroy rubber.
Guess I should have also said that the job is straight forward and requires no special tools or knowledge required.
