Brake controller connector location help
6659 Views 8 Replies 6 Participants Last post by  motocopter
I bought a controller with a direct plug to factory harness for under the dash, does anyone know where its located (factory plug in) before I take the dash apart looking for it?
Thanks
1 - 9 of 9 Posts
It's just above your right shin when your foot's on the gas pedal (likely taped to another harness).
Here's a pic I found.
http://www.clubfrontier.org/forums/f23/05-08-frontier-tow-relay-install-hitch-pics-27530/#post548960
It is right by the OBD-2 port underneath the dash. There is no need to disassemble anything. It is the connector hanging down with the red, white and, blue wires in picture.
Thanks
Done
I need some help....if i was to forgo the plug adapter, and splice the wires together.
which wires go where?
meaning which nissan wire goes to the red wire....the white wire....the blue one....etc?
thanks,
Robb
thanks,
Robb
Can't answer that -- I got the plug in lead from the dealer. They gave it to me... :)
Suggest you spend the $15 or so, and not chop your wiring harness...
I'm still searching but, what is the connector with the orange wire for in your picture? I have this connector available and is secured. Is that the e-locker?
1 - 9 of 9 Posts
