1 - 3 of 3 Posts
I just changed my rear rotors and pads . Passenger side went smooth put everything back together and it's good to go . Driver side slider pin bolt cracked off so I had to buy new slider pins and bolts . Put everything back together and go to tighten slider pin bolts . The slide pin kept turning but it still felt snug (not super tight ). When I wiggle the caliper now that it's all back together it seems to wiggle . Is this ok ?
how old is the truck? did the slider pins seat against the caliper frame? As to 'is the wiggle ok' I would ask how much does it wiggle and how does it wiggle?
it's a 2012 and it wiggles a decent amount . I think I may have figured out the problem. Autozone gave me the wrong slider pins . I picked up the right set just now . Have to wait till tomorrow to swap them out . I'll let you guys know
1 - 3 of 3 Posts
