Thanks for having me.
I bought my 16 yr old a 98 extended cab 2wd for cheap from a buddy. Cluster is dead needed complete overhaul of front brakes and windshield.
Car ran ok but seemed like timing was off. Had a coolant leak under the intake manifold so we had to take that off and fix. The manifold was cleaned before install.
Son drove for a month the truck started runnning rough and wanting to stall when comming to a stop. Well a week ago truck died and had to be towed home. Code 1320
Distributor i thought and that would explain the bad idle. Replaced distributor plugs and wires still no start. Ended up being the fuel pump.
Now with all the new parts truck still running rough with the idle going up and down. I have cleaned the MAF and am currently getting no codes.
Compression test
160, 170, 160, 172.
Here is a picture of the rotor at TDC. Black mark is #1 wire. You guys think oil pump is a tooth off?
Also notice that the dist. Has to be turned all the way clockwise for it to run.
Thanks for the help I just can't keep throwing parts at this thing.
Also what about the compression results?
Compression test
160, 170, 160, 172.
