I have just ordered a boost controller and was wondering if any one knows the maximum boost capable on a zd30dt diesel in a d22 navara 07. I have installed a 2 and 3/4 exhuast and custom snorkel and filter box which has already got me more power but want to try and get more out of the turbo. Any advise will be much apprciated:noworries:
raising boost will most likely throw a code and send the ecu into limp mode, you will have to fool the MAP sensor into not seeing as much boost, which would then leave you under fueled past the factory limit
Discussion Starter #3
how would i know that the ecu is watching the boost.
not 100% sure but afaik boost cut is something like 30psi.
have you chipped it at all?
if not don't waste $$ on boost controllers. these run 18psi stock (with your exhaust, normal is 15psi) and are fairly well under fueled. increase fueling before playing with boost levels.
pop into The Navara Forum and say hi :)
