1 - 20 of 29 Posts
I was installing xtp ims, and i lost one of the bolts that go in it I couldnt find it on the ground or in intake hole. So i put it all together, and started it up, it made like crackling noises and i shut it off. Tried to start it one more time and same thing. What do i do?
Find that bolt.
Im gonna give it my all tomorrow. If i faili guess its time to call a tow truck. Wich suks cus the truck is pretty new.
You shouldn't have started it if you couldn't find it. Now just take your time looking and you'll find it, best of luck and let us know how it turns out.
if you know someone who has a bore scope (camera and light on flex line) you can put it in each port and see if and where it is. Harbor freight has them for less than a tow would cost you. Mine was $200 a few years back but $75 is do-able. Mine even has a hook or magnetic attachment to retrieve things.
Again, I'm hoping you're successful in this.
I appreciate it gonna try everyhting i can. I only started it because i thought it fell behind motor somewhere You dont think im screwed just from starying it do you. And what do you think made the godawful noise and shut it off right away basically.
Thank you again a bunch tho. Greatly appreciated. If anyone else knows anything else please chime in.
That is understandable but you did it twice.
It would end up where your valves are located.Hopefully the noise you are hearing is the bolt bouncing around while the valves are cycling and it is still above the combustion chamber. Could be the bolt is between the valve and valve seat which would be major head damage.It could of went pass the valves and into the combustion chamber. If it exited through the exhaust system,I don't think you would hear anything.
No matter what is causing the noise,it's not good.
If you can't locate the bolt with the camera than I would remove the lower intake manifold.If it entered the combustion chamber than you will have to remove the head/heads.
It's been ages since I worked on or even thought about an overhead cam/cams motor(Honda fours) so I maybe completly off base. Just trying to think it through.
Reactions: ef9
Those bolts for the spacer are pretty long; I have a hard time believing they got past the valve. You'll have to remove the upper plenum and spacer and do some fishing with a magnet, or, locate it with a bore scope, if you have access to one and then fish it out.
Go rent a bore scope. Good luck.
I did not know that.I have no clue what they look like.I pictured short,flathead machine screws.
Rogue Admin
2007 LE 4x4 Crew Cab Long Box
No, they are long but there are also long guide bolts to assist you to line up the intake (I just checked and my spacer is a different brand, perhaps the OP's mounting hardware is different). Here is a pic of my spacer right as I dropped it in, prior the whole head was covered with towels to prevent anything dropping in.
Discussion Starter · #12 · (Edited)
Ya thats the exact bolt. Basically i loosened them up all the way but left them in as guides. Went to put spacer on, it got locked up on them 2 bolts from me being slightly crooked, when i took off spacer to retry, it pulled one out with it and down it went.
Im getting ready to go to store for fishing supplies now. Thanks yall. Keep your fingers crossed.
Google a retractable claw pick up tool, it is a very valuable item in this situation.
Rogue Admin
I think you just cost me $27.50, now I can have 1 with and 1 without a light. Can never have too many tools. This must be why my tool box is as tall as me and has side boxes too.
Thanks for posting that.
Yup,need to buy another roll away. Outrageous prices nowadays.
Any update on this situation?
Discussion Starter · #18 ·
Yes i didn't have any luck with the magnet. Looks like ill get it towed to a shop n see what they can do. Wonder if me starting it twice made it go too deep for the magnet to reach.
Maybe you weren't reaching where it's laying off to a side? Any chance you can buy, borrow or rent a scope so you can look in the ports and see if it is I fact visible and accessible or not?
If it fell into a cylinder then is a guess of which bank it's in.
Where are you from, your profile isn't showing that.
Discussion Starter · #20 ·
I dont know how to use that if i rented it. Im from Elkins West Virginia. I do greatly appreciate everyone trying to help tho. Hopefully i didnt ruin this motor with only 20k on it.
1 - 20 of 29 Posts
