Hello everyone,
I am looking for so help finding new body mounts for my 2011 KC Frontier. I've been looking around here and TheNewX for awhile trying to find part numbers for OEM or aftermarket mounts with not much luck. The majority of the mounts I've found have been universal but I'm not sure if they will work.
I am most interested in the bed mounts if I can find them. Driving down a bumpy road, it sounds like the bed is about to fall off. I know we have loud tailgates to begin with but I have a shim in that to help reduce that noise which does help.
I believe my two front mounts are also bad. Seems like a common complaint around here. Anyone know the numbers for those too?
Hello everyone,
I use CourtesyNissan because they have the big parts diagram pictures. I put in a 2011 Frontier V6 and went to "body", and then "Frame and Compenents". The parts you want look like parts 18 (cab insulators - pick which area) and 19 (rear body insulators). I ordered body mount insulators from them a while back and took a guess at what I wanted by the pictures and it worked out. I believe parts 18 and 19 represent all the roundish shaped rubber insulators seen between the frame and the body/bed.
https://www.courtesyparts.com/auto-...gas-engine/body-cat/frame-and-components-scat
How many of each?
