1 - 4 of 4 Posts
I just ordered a 3 inch body lift for my 98 from 4x4parts.com and I was wandering if anyone else has bought and installed this kit and if so did you have any problems with it?
Other than it being tedious no real problems. Make sure you have all the parts accounted for before you start and expect to take at minimum a full day to finish it.
i've had the same kit on my truck for about 4 years and have had no problems. as said previously...it's a big job and will take a day or two. i did mine by myself with limited tools and it took me about 15 hours including breaks, etc.
remember to use lock-tite on the bolts when tightening everything back up. and still its a good idea to go back and retorque the bolts after about 100 miles. just to make sure everything is good and tight.
also, get some good work gloves and find a buddy to help.
Thanks yall, i'll have to make sure I do it on my day off. And I also have access to a small shop with a chain hoist that I could lift the body up with but I'm not sure if that would help speed things up or slow me down.
1 - 4 of 4 Posts
