1 - 4 of 4 Posts
Hey guys,
I just received my 3" body lift from 4x4 for my '04 crew cab longbed. I'm looking through the instructions to make sure I have everything. I ran into a little issue with the rear bed lift blocks. In the instructions they have a shortbed pictured. I understand that the crew cab has 8 body mounts up front, 4 on each side. And then is it 4 for the back, or 6?
Because I only have 4 blocks left over. The instructions say a 2 x 3 x 2 3/8" spacer block is used for the first mount. But the problem is the block I received is 2x3", and doesnt look like the one in the picture.
Second problem, the picture of the first mount (closest to the cab) looks totally different than my truck. Since I have a longbed, would I need a total of 6 blocks for the rear, 3 on each side?
Here's a picture of the spacer block, does this look familiar? This is the only part I have left over for this. Am I missing something, or am I completely retarded!! I'm gonna call 4x4 in the morning but I just wanted to see if anybody had this issue.
thanks!
Games Indoor games and sports Dice Recreation Metal
The part in that picture looks like the support blocks you put on top of the frame rail in between it and the bottom of the bed. Its not actually a mounting block, just something to add strength for hauling heavy loads.
Im not sure about the number of mounts or if there is a difference. Can't you just crawl under and look?
ETA: Here's what I mean (on the right side)
source: http://www.bigpasta.com/fronty/bodylift/body_lift_install.htm
yup, i have those blocks as well. I was asking about the bed mount that is closest to the cab. after several emails and phones calls to 4x4/performance accessories, turns out i have the wrong spacer block, since this one is only 2" tall. i need one that is 3" tall. this is what was throwing me off all along...
1 - 4 of 4 Posts
