For some reason I can't find this screw and I want to replace the Coolant in my truck. FRONTIER 2014 V6
What type of coolant do you recommend besides the Nissan original?
Would you recomend a chemical purge?
Thank you
If your engine is a VQ-40 like the one in my '06, there are no bleed screws. This has unfortunately become increasingly common in modern vehicles. I used Prestone green in my Frontier, but others here might have better suggestions.
Reactions: Mikelodeon
Fwiw, factory coolant supposedly good for 130K miles, IIRC.
Get a coolant that states "safe for all makes and models"; these modern coolants get re-packaged as different "brand names" such as Nissan but all are lower pH to be safe for modern engines with aluminum parts such as radiators, cylinder heads, etc.
At Walmart - PEAK Original Equipment Technology Antifreeze + Coolant for Asian Vehicles - Blue.
For Nissan 2009 and up. Matches OEM antifreeze.
