I started with a '13 RWD, CC short bed with stock suspension. I had the "hit a big pothole and the rear of the truck almost changes lanes" effect for years. When I started towing a travel trailer at 95K, that effect was accentuated to a "white-knuckle" degree. I put Bilstein 5100 (silver) shocks on the rear, and instantly the ride was sure, rock-solid and predictable. Fast forward to 130K, and I add Blue (1,000 lb) Sumo Springs to reduce the sag and to try to preserve the life of the the original leaf springs. With ~300 lb tongue the sag was on the order of 1.5" to maybe 2". The Sumo Springs are in constant contact with the frame, as most here have found, and that is fine. They reduced the sag to about 0.5" at ~300 lb tongue. But now I am almost back to the original ride -- bouncy almost like a pogo stick, feels like getting airborne sometimes. This is with and without the load. I understand how springs and dashpots (shocks, here) work together and I know that they have to be tuned to each other to work properly. I am just surprised that I threw it so far out of whack that I am falling almost back to the beginning from such a nicely-performing setup. I do have new KYB struts on the front with new coils (SR4201 kit) with <1K on them.
Next chance I get, I will jack the thing up and unscrew the helper spring bodies and go for a test drive to compare. I am cautious about new leaf springs from (e.g.) General Spring, since that could throw out the apparently-sensitive balance with the shocks as well.
Could it be that ~35K on the Bilstein 5100s is near the end of their life, with fairly extensive towing during that time?
Does anyone else have a similar setup?
Thanks for any insight.
