Hey all, I'd like to kill two birds with one stone and replace my shocks while doing a leveling kit. I have been reading about the differences between the Bilstein 5100s and 4600s and from what I gather, the main difference between the two is the 5100s are height adjustable so in essence you could use them as a front leveling kit to a degree. Unless directed otherwise by all of you, I'd like to go with a leveling kit like the ReadyLift and just do quality replacement shocks/struts. Will the 4600s work fine with the ReadyLift or do I need to use the 5100s for the increased ride height with the ReadyLift installed?
Thanks!
Nothing wrong with doing the 4600 plus a spacer, but the better/cheaper solution would be to just get the 5100s and set them at or below 2". With the spacer you will get coil bucket contact, the 5100s won't let that happen. Besides that the 5100s may feel slightly firmer since you are adding preload to the spring for the lift. Honestly the best solution for what you want is 5100s set at 1" and a 1" lift spacer on top. This allows for a nice balance between ride quality and lift as you won't get coil bucket contact and the ride is the nearly the same if not better than factory. In case you weren't aware a 2" lift up front put the truck nearly level.
