1 - 11 of 11 Posts
Im looking at getting a set of 20s for my truck and i want to have the most sidewall possible.
Discount tire has 285/50r20 for the rims i picked out and they come out to 31.22" tall is that too large?
Stock tires are 235/75r15 which are 28.87"
This is for a suzuki equator 2wd base.
sorry if this has been asked before but i couldnt find an answer in the search
Banned
Id look at Toyo Proxes
they fit just fine I had them on my truck for 2 summers and this spring no rubbing and I have a 1in drop up front. The hankook Venturs STs are great tires along with the Yoko prada spec Xs
Irongrave-
You're running 20's with the tire size listed above and have no rubbing at full lock and no trimming was needed? I may need to look into that setup. They look pretty sweet on your truck but I figured you had trimmed to get them in there...
no hit that i could see and power was the same but could drive the truck deeper into turns and not let off the gas because the 285 has gobs more grip
1 - 11 of 11 Posts
