1 - 4 of 4 Posts
I was speaking with an engineer this afternoon on another matter and he showed me what is essentially new larger brakes for the D40. He wants to build a kit up with new calliper and rotor setup that will be a direct bolt up application. Only early days so far but the kit will include new slotted rotors from DBA.
Now all things being equal there is a good chance the kit will fit the Fronty so fingers crossed girls n boys
Any Idea when these might be available? Im almost in need of some new pads and I would like to overhaul the entire braking system? Price as well, any idea on how much?
Thanks Aussie Fronty.
Stillen sells a set that uses AP racing calipers and larger rotors but they also require the use of 17" or larger rims.
Has anyone run the numbers and figured out if a set of Brembo's or etc... can work on our trucks with the right adapter plates?
1 - 4 of 4 Posts
