that 'plastic thing' on the BATT Ground lead is a current sensor. (VVCS) It is important you ground items to the frame and NOT directly to the batt. Grounding directly to the batt bypasses the current sensor and the alternator won't generate enough amps.
Yes I did I was able to get 1/0 wire through the center of that, it took some time and I had to use wire lube but it went.any updates, did you ever complete the big3?
Can you post pics of each upgrade. I need to do this for my sub upgrade>Yes I did I was able to get 1/0 wire through the center of that, it took some time and I had to use wire lube but it went.
I just replaced every wire under the Hood with 1/0 and than ran 2/0 to a second battery and amps in the back.Can you post pics of each upgrade. I need to do this for my sub upgrade>![]()
I will try to get a picture of it I remember the wire being short like maybe a foot from the batteryCurrently running a saz1000 w/a sundown sd-2 10" and a fsd125.4 on a pioneer double din.
upgrading to a sundown x-10 v.2 d2 on a fsd2600.
I am honestly having trouble locating the ground to the block
I never posted my build on here but I have part of it on diymaI like the lows
Here is my build and how it went from sa8's to a sd-10... Ill update it when the builder starts my new box. I am basically going to cut out the metal under the passenger rear seat. I was under quoted at 1.1 ft^3
http://www.clubfrontier.org/forums/f103/2007-se-crew-cab-audio-build-80010/
A pair of Z-10's! DAMN!:surprise:>![]()
I have a mechman Alt sitting on my tool box at the house right now along with another 1000 watt jl mono and a set of hybrid audio speakers I am going to try a 3 way active set I need to post some updates when I do it seems like it is the last that I work onGreat build!
I like the hdpe over the big door holes! I went ghetto and used cardboard lol. I might redo mine with this as its easier to get in and out of.
Did you upgrade your alt? I am looking at a mechman [email protected] out the door. Will pull the trigger once my box is being worked on.
