just wondering to see what brand bump stops you guys have on your titan swap. i was looking at the radflo or fox bumpstops. is 2inch body with 4inch travel the right size?? thanks
no, 2" max stroke, you only have 10" of travel. I run center shock so 5" compression, 5" of droop. So if you run a 2" bump, half way out your arm you have 1" of free compression travel. Lot of wasted money on shocks if your not going to use them:comphead:
So get the shortest bump you can, and run it as far out as you can.
1 - 2 of 2 Posts
