1 - 20 of 74 Posts
Hi all,
I'm just curious what aftermarket radiator everyone is using to replace the OEM one. I am going to switch mine out eventually before the warranty runs out to prevent the dreaded coolant/ATF mixture.
So, what is the best aftermarket radiator for our trucks? I have a 2010 V6 Auto.
Subscribed!
My 06 truck is nearing the 80K limit for the warranty. So as soon as i hit that im changing out the rad. I to am looking for a good aftermarket one.
I've asked this question a couple of times myself. No one has given me a solid answer. Looking to replace my friends 08.
Subscribed!
Just a heads up: The extended warranty has been...extended? lol, to 10 years/100,000 miles. I received a letter from Nissan earlier this week.
it has been extended if you want to spend a couple grand - read the fine print
Son of a gun. Yup...
I sold the truck it applies to a few months ago so when I got the letter I didn't bother looking into it at all. I just read the paragraph that says "Nissan is pleased to announce..blah blah blah..."
Griffin makes a really solid aftermarket rad for our trucks. A little pricey but you get what you pay for. Search "Griffin radiator" on here. There is a thread pertaining to this.
Steve Benecke
Amsoil Independent Dealer
www.lubedealer.com/code3synthetics
I put in a Griffin with dual Spal e-fans. Also put in a Nismo 350z tstat, and have not had any cooling issues, even when hauling a$$ in the desert. The radiator was about $900 with the fans, and its a direct replacement.
^ what?
The radiator issue has nothing to do with the rear end. The plastic end caps of the radiator crack and cross contamination between the rad fluid and ATF happens causing the strawberry milkshake of death.
I think the guys name at Griffin is Benjy if I recall correctly.
I gotcha now...
But the radiator issue was pretty much resolved 2007 and later. I have an 2006 and had no problems for 60k miles before I crushed mine in a wreck.
I gotcha now...
The suspect radiators were not changed until 2010.
1 - 20 of 74 Posts
