1 - 7 of 7 Posts
I'm looking for some kind of tie down that fits into the track on the sides and front of the bed, would slide into these rails and lock in
[/IMG]
also it would need a D ring to tie to.
anyone seen anything like this?
Any ideas greatly app.
[/IMG]
a utilitrack tie down cleat?
stock cleats... the only problem is that they dont "lock"
All you have to do is turn the cleats and they will come out.
Maybe add the D-Rings from a stock non-Utli-trac equipped bed (although they can be unbolted w/tools just as the Utli-trac itself can be) & a cable lock?
If you know where you would need a secure point you could drill a hole perpendicular through the Utli-trac and use an extended shank Master lock.
What are you trying to secure?
Could maybe try taking apart a cleat, take the black tightening wheel off of the utilitrack tie down, and see if it could just be bolted back in. Same Idea as the cleat is now, just not ajustable by hand, would need a wrench to move it.
1 - 7 of 7 Posts
