1 - 20 of 25 Posts
2022 Pro 4x, Baja Storm
Anyone know the carrying capacity of the bed rails for the '22?
Considering a DiamondBack HD cover to carry my 4-wheeler. But the cover is not light (around 120 lbs AFAICT) and the 4-wheeler is close to 800.
Thanks!
2021 Frontier SV CC 4x4; 2018 Frontier SV KC 4x2
So you wanna put 920# give or take on TOP of your bed? That seems a little sketchy to me. Even if the rails can handle the weight, your center of gravity would be ridiculously high.
Unfortunately it won't fit inside in the bed. You are probably right about the height, but I'm not ready to throw down the money for a decent trailer I'll use 5 times a year so more info -> good.
I take it you don't know the number?
No, I’m sorry, I don’t. If it’s rated to carry weight on top of the bed sides at all, there’s no way it’ll be rated high enough to do that. It’d be too much of a liability if they said it could handle that amount of weight & then someone rolled the truck because of it.
2022 Frontier SV 4X4
For something like that, check with U-Haul and see if they have a large enough trailer to rent. For only a half dozen times a year and it's a heck of a lot safer (and not too expensive). I can't say I've ever seen a truck manufacturer publish that type of information. As JVRaley eluded, the higher you go the lesser it will be because of the CG.
They do. I rented one once since buying the Frontier to take the 4-wheeler locally. It was very reasonable for a short trip like that.
But I was under the impression from their website that you can only rent those small, open trailers for the day. Most of those times I'm going to Colorado for week long trips. BUt I'll reach out to a local U-Hal and just ask them personally - never hurts to ask.
That would absolutely be the ideal for the short term.
What kind of 4 wheeler you talking about. Most quads are 48" max. The bed is 61" wide. You might have to ride up on the wheel wells.
Or are you talking about the side by side of some sort.
Its an older Sportsman 550. The width from outer edge of tire to outer edge of tire is 55".
The bed is 61" wide, but the narrowest point (at the tailgate) is 55".
They rent for as long as you need. I have a sportsman as well and this is what I do. They will also rent you an enclosed for a few bucks more. I’ve done this for multi-day trips where I want the extra security at night. It would take me 4 years to spend as much as I would on a trailer and I don’t have anywhere to store it (thanks HOA)
The Diamond Back HD and your truck will also. I have one, also had stock leaf's, 5100's and this load was around 800-1000 lbs. I have loaded up heavier, but not a fan on stock leaf's. However, you will crush the weather stripping over time, and you will need to check the clamps holding down the cover. You most likely dont have them tight enough without a load on it. Would really suck to have the whole thing slide off in a turn. Once tight enough, your doors will be harder to close... Its a balance.
Motor vehicle Wood Gas Building material Automotive exterior
Reactions: GreyFox
  • Haul up to 1,600 lbs. on top
Yeah, but that gets rough. Still should try to adhear to the spec payload weight. Obviously I don't know what mine is as I have had way too much too many times...😂. Absolutely love the cover though. Light weight, super strong.
OP,
You could get a fold-able trailer from Harbor Freight or Northern Tool if you have storage issues.
Wheel Tire Tread Automotive tire Rolling
Discussion Starter · #17 ·
@Bar None - I've seen that one. I was nervous taking that on the 800+ mile trips I take between Texas and Colorado as well as some of the rutted, washed-out roads I have to take. I've seen a wide range of reviews. Not to mention the total width of the 4-wheeler is 55", so would be hanging off pretty far off the sides. Do you have this?
@davedibbs Just ordered the Diamondback!
Discussion Starter · #18 ·
I assume you are taking this from the Diamondback website. That is in fact how much the cover itself can hold. But ultimately, the cover needs to distribute that weight to the bed sides. There seems to be no published numbers for what the bed sides themselves can hold.
2022 Frontier SV LWB 4x4
It happens here with sleds. A quad and sled are about the same weight.
Tire Wheel Vehicle Car Motor vehicle
Not sure if this helps any but i was doing some research on the nismo bed rack and noticed that the static capacity is 1200 lbs while dynamic is 750. Obviously doesn't say anything about the bed rail capacity them selves but if the utilitrack can handle a 750-1200lb load...
1 - 20 of 25 Posts
