My 2016 CC 4x4 SL LWB has the Nissan spray in bedliner and utlitrack. Has anyone used a bed mat with this setup? If so which one and did you cut out for the utlitrack? Did that present any issues?
Thanks,
Jeff
I always use the rubber mat over my bed lined bed. No, I did not cut it for the utilitrac as I use the side rails on the rare occasion the I use the trac.
I have a rubber mat in my Pro 4x with spayed in bed liner and utilitrac. I did not cut slots in the mat for the bed tracks.
(The mat I have came out of my 06 Toyota Tacoma access cab. I cut the mat down to size. Only funny thing is the Toyota name is on the mat.).
I have only had to use the side cleats / rails in what I have hauled so far.
Dee Zee DZ86965 Heavyweight Bed Mat https://www.amazon.com/dp/B000VUATBE/ref=cm_sw_r_cp_api_AfvIybHR4YYM5
I have a sort bed and used the above mat. I had to cut it down to fit and it worked great. I used the drop on my tailgate, covered all but 3-4". Saves my knees. It should fit your long bed well.
I just take it out and leave it in the garage when I need to use the bottom rails. If that's not an option, it easily rolls up. Just use a ratchet strap to keep it from unrolling. I also don't see where it would be too complicated to cut a few holes out where you need them in order to use the tie downs.
Don't know if you have dogs or not, but I feel the rubber mat makes the bed more comfortable for them because their claws and paws don't slide around and the bed surface gets leveled out providing them with a nice surface to lay down on.
I'll post some pics later if you want.
.02
I have a DeeZee bed mat that I use over my spray on liner and the utilatrack. When I need to use my floor utilatrack, as when I use it for mounting my custom bike rack, I pull the mat out. Otherwise I use the side utilatracks or the OEM rope hooks that I added to my P4X.
