1 - 7 of 7 Posts
Since I got my truck I drove it alone and never noticed the bed bouncing, yesterday my kids wanted to go for a ride to the shopping mall and instead of using my wife car I drove the truck, while on the high way my son noticed the bed was bouncing, I drove 50mph, highway is uneven in some parts, I had my wife drive the truck, I sat in the back seat and it bounced alot, is this normal or I need new rear shock's, I bought the truck second hand with 45k miles.
Is the bed bouncing off the frame or is there just a lot of rear suspension movement?
If it is the rear, then it may be time to upgrade shocks. It may also be a good time to add lift if you are going that route since you may be already investing in shocks.
maybe also just check make sure the bed mount bolts are tourqed to spec i believe they should be tourqed to 45 ft lbs
Discussion Starter #4
No it is not bouncing off the frame, yes I thought about shock's, I have a trailer hitch so I imagine the last owner must have towed something.
all bolt's and nut are tight to spec's, like I said, I will go for the shock replacement, I was asking just to make sure we didint had a bed problem, thanks all.
Discussion Starter #6
Had a F-150 and it did jiggle from new, but not as drastically as I saw it on sunday from my truck.
1 - 7 of 7 Posts
